- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK53S no internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I recently bought an Orbi RBK53 to use with my Cox (ugh) internet at home. I turned the panoramic modem/router into bridge mode (Technicolor CGM4140COM) using the login page at 192.168.0.1. After this I unplug the device and plug it back in, connect the orbi and satellites as instructed using the app. The App on my galaxy S10+ is able to connect to the orbi, but unable to detect an internet connection. If I plug my laptop into the modem I get internet, but not if I plug it into one of the ports on the Orbi.
Has anyone had similar issues or any suggestions for me to try?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset the RBR and use a wired PC or laptop connected to the RBR and walk thru the setup wizard with a web browser. I would also power OFF the isp modem for 30 seconds while the RBR is reset. Then log into Orbilogin.com or 192.168.1.1 with a web browser and begin the setup wizard.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK53S no internet connection
The setup client then asked me to try an alternate MAC address....so I tried the one on the modem/router combo from Cox and that seemed to do the trick.
Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
