- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR 40 not listed for manual firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to update the firmware on my RBR 40 after updating my satellites to V2.3.5.34, and have a few questions: 1. Does V2.3.5.34 apply to the RBR 40, or is V2.3.5.30 the most current firmware? 2. My RBR 40 is not listed under Advanced/Admin/Firmware/Manual update; how do I access it to update it to V2.3.5.34 if it needs to be updated? 3. On the Netgear support page the RBR 40 is no longer listed, does it use the same firmware as the RBS 40?
Thank you in advance for your assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR 40 not listed for manual firmware update
@MyJunk wrote:Trying to update the firmware on my RBR 40 after updating my satellites to V2.3.5.34, and have a few questions: 1. Does V2.3.5.34 apply to the RBR 40, or is V2.3.5.30 the most current firmware? 2. My RBR 40 is not listed under Advanced/Admin/Firmware/Manual update; how do I access it to update it to V2.3.5.34 if it needs to be updated? 3. On the Netgear support page the RBR 40 is no longer listed, does it use the same firmware as the RBS 40?
Most will tell you that the FW for both the router and sats should match. The real question is WHY are you doing manual updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
v34 is the latest for both RBR and RBS40:
https://www.netgear.com/support/product/RBK40.aspx#download
If you do, use a wired PC, web browser, IE11 or FF, and unpack the .zip files. Update the RBS first then RBR lastly.
If your systems are working with out any problems, you can keep whats loaded. "if it works, don't fix it!"
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm doing a manual update b/c the RBR 40 is not listed in Advanced/Admin/Firmware...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My system is working, but I hadn't updated my firmware in a while; so, when I got the notice about V2.3.5.34 I figured it was a good time to do some Spring updating.
When I went to Advanced/Admin/Firmware Update one of my Satelites automatically picked up the update, and I had to manually update the other. Under "Online Update" the RBR40 says "No new firmware version available" which was the first part of my question if V.34 applied to the RBR40. When I went/go to "Manual Update" my two Satellites are listed, but the RBR40 is not.
If in fact V.34 does apply to the RBR40, how do I update it if it is not listed as a device?
Again, thank you for your assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MyJunk wrote:My system is working, but I hadn't updated my firmware in a while; so, when I got the notice about V2.3.5.34 I figured it was a good time to do some Spring updating.
It's best to leave it alone. No cleaning or updating required.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
