- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR wont load anything and cant connect to it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all, after about 3 years my wifi started acting up, so i power cycled my system. now i cant connect or anything to my RBR50, just like this video https://www.youtube.com/shorts/DCk8iw52QB4
Is there anyone who know a way i can reconnect to my device and explain it to me like im new here, been using 5 days on this and for this expensive system it should work better, its probably a firmware problem. there is no light what so ever on the top, but there is that green power on it. please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR wont load anything and cant connect to it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a factory reset and setup from scratch using a wired PC and web browser?
Can a wired PC connect to the RBR? Does it get internet services?
What devices are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have tryed connecting with cable, admin /password, didnt get me anywhere eiter , reset wont work, just like in the video in the first post, he bought a new router, im about to do the same here, and never go back to this brand, because there is no help to get for there firmware that probably broke it after alittle over 2 years 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you press the reset button for 15 seconds then release and see if you could access the RBRs web page at 192.168.1.1 after the top ring started to pulsate WHITE?
Can't be sure that FW would have broke your unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no light at all in the top, and it only lights green when there is power on, the satelite can reset and works pretty much as expected, but i cannot figure out how to connect to my main RBR, i tryed 192.168.1.1 and 10.0.0.1 and .com and .net with orbilogin, even plugged in directly into my PC and no going throug a bridge
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try swapping the power adapter with the RBS to see if anything changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
allrdy did that, switched ethernet cords aswell, pretty much tryed anything the past 5 days, my technical knolewdge is running dry tho lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last resort then:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Try nmrpflash:
https://github.com/jclehner/nmrpflash
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000P-V1-4-1-50-Update-workaround/m-p/22488...
https://community.netgear.com/t5/Orbi/Orbi-RBR50-seems-stuck-in-boot-loop/m-p/2010016/highlight/true...
https://community.netgear.com/t5/Orbi/Is-my-13-month-old-RBR50-bricked/m-p/2011090/highlight/true#M1...
If any of this doesn't bring the RBR back, I would presume the RBR needs to be replaced.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you will give this a try again, allrdy tryed tftp, but didnt work, will try with this guild, thanks for you time 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the nmrpflash as well. If fails, get the RBR replaced.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This may seem silly, but do you feel or hear the click? There is a tiny push button switch on the circuit board that is supposed to line up with that tiny hole.
The Ring LED at the top of the case is supposed to go through a sequence of pulsing, abruptly turning on/off, etc. for about two minutes until it finally displays either blue or magenta for two minutes. After that, no light at all.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
I have found that TFTP is really sensitive regarding timing. There is a short window of time during the power up when the router listens for a TFTP connection. Too early, and there's no response. Too late, also no response. The "sweet spot" is not very long.
On one occasion, it took me six attempts to get firmware to load.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes there is a click, im working with networking cards here in denmark, we test using failsafe button on the cards aswell, so im not that new to this hardware, its the software im not a shark at 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a chance that nmrpflash is more sophisticated than TFTP and does not require precise timing. (Those six attempts were a demoralizing effort until, Voila!, it took.)
Not much to lose except time and patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Kvappe,
Welcome to the NETGEAR Community!
Were you able to use the suggested methods to connect to your RBR50?
Best,
Kevin
Community Team
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
