×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RBR20 Base Stuck in Reboot mode
Eldread
Follower
Hi. We had a storm earlier and during it the power flickered for a split second and we lost the Internet. I’ve since confirmed that I do still have Internet connection coming to my Comcast router (in Bridge mode), but my Orbi mesh system is not working and so I don’t have Wi-Fi. I have an RPR 20 base, and the light is stuck on Amber. No matter how many times I try to do a reset, the light always comes back on solid amber. I tried disconnecting power and cycling through it a few other things I found online, with no success. Does anybody have any other ideas? Or might I have a hardware problem and should look into replacing the unit?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: RBR20 Base Stuck in Reboot mode
Try taking the power supply from one of the RBS and plug in with the RBR. Press the back reset button for 15 seconds then release.
IF this doesn't resolve anything, you'll need to get the RBR replaced. Contact NG support to see what options are available to you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Discussion stats
  • 1 reply
  • 330 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
