Orbi WiFi 7 RBE973
Reply
RBR20 Ehternet port doesnt't work after firmware upgrade
MartienR
I installed the newest firmware to my RBR20 (v2.5.1.16). After the reboot of the system, the ethernet port on the router doesn't work anymore. I have attached a netgear gs105 switch attachted to it. Any ideas?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
MartienR
Re: RBR20 Ehternet port doesnt't work after firmware upgrade
Issue solved. When I connected a device directly (without NG gs105 switch), it did work. Problem was the switch. Bought a new one (TPLink) and everything works again.
Message 3 of 4
All Replies
Guru
Message 2 of 4
MartienR
Message 3 of 4
Guru
Interesting, what rev version is the GS-105 switch? Was the switch just bad?
Glad you got it resolved.
Message 4 of 4
Discussion stats
  • 3 replies
  • 507 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
