Orbi WiFi 7 RBE973
Reply
RBR20: Slow backhaul
Spanky_Pants
Follower
RBR20 running firmware V2.5.1.16
RBW30 Orbi Satellite, firmware V2.5.0.4
Speeds to the RBR20, and from the RBR20 and Satellite (wireless) are all ~450mbps.
However, anything connected to the RBR20 backhaul ethernet port is limited to ~ 90mbps
Ruled out any cabling or switching possibilities. Slow backhaul also existed prior to updating firmware to V2.5.1.16
Any ideas on correcting the slow backhaul, or is this a known issue?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: RBR20: Slow backhaul
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
Has a power off for 1 minute then back on been performed since last update?
Message 2 of 2
Discussion stats
  • 1 reply
  • 391 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
