Orbi WiFi 7 RBE973
Reply
RBR20 & RBS20 Firmware 2.3.1.58
wrh42
Follower
My RBR20 now has Firmware 2.3.1.48 installed, but it lists Firmware 2.3.1.58 as available. I have been doing manual updates because of various problems I've had with the automatic update system. To perform a manual update I need the 2.3.1.58 zip files, but they are not listed in "Downloads". Does anyone (Netgear) know where to find these zip files?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Lkc037
Re: RBR20 & RBS20 Firmware 2.3.1.58
Message 2 of 4
Guru
Files have not been posted to the download site as of yet. I presume NG will post them when they get ready.
Some release info:
V2.3.1.58 Release Notes: [Bug Fix] Fixes the issue where the time zone can't sync with the satellite. [Bug Fix] Fixes issues with the guest network control using Alexa. [Bug Fix] Includes security fixes.
https://community.netgear.com/t5/Orbi/Orbi-RBR20-Losing-Configuration/m-p/1746621/highlight/true#M60...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 4
Blanca_O
NETGEAR Moderator
The FW 2.3.1.58 has the following changes :
• Fixes the issue where the time zone can't sync with the satellite
• Fixes issues with the guest network control using Alexa
• Includes security fixes
The said firmware is for RBR40, RBS40, RBR20, and RBS20.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3530 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
