Orbi WiFi 7 RBE973
Reply
RBR20 & RBS20 x2 Giving very poor WiFi performance
maortiz1969
Tutor
I am completely frustrated with this system.  I've owned it for about two years now and had no complaints other than the fact that I cannot designate which Satellite my stationary devices should connect to.  Huge flaw in my opinion.  Regardless, I have had no complaints otherwise . . . until now.
I just upgraded my service to 1/1Gb from 200/200Mb and while the base RBR20 Speed Test shows beautiful numbers, when ever I test any of my WiFi devices I get subpar 100mb throughput, if I'm lucky.  I am literally sitting right next to my satellite, which is within line of site of the router, with my laptop and iPad and get crappy throughout.  I have searched all over and have not found anything suggested to help.  All settings have been enabled and disabled, tested and re-tested with all possible configurations.  I am on the latest Firmware, V2.5.1.16 on all three devices (RBR20 & RBS20 x2).
To note, even when on 200/200mb I never hit 200 unless it was during the uploading test.
Can someone please assist me in getting this sorted out?  I'd hate to think I've had bad Satellites all this time and my warranty expired a long time ago.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
Guru
Re: RBR20 & RBS20 x2 Giving very poor WiFi performance
What are the speed results with a wired PC or laptop connected behind the RBR?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Message 2 of 10
All Replies
Guru
Message 2 of 10
maortiz1969
Tutor
We're onto something!  Getting better throughput now.  Doing some testing and tweeking and I will get back to you.
Message 3 of 10
Guru
Let us know how it goes.
Message 4 of 10
maortiz1969
Tutor
So I am averaging now 215mb down on my WiFi devices where as it used to be below 100mb.  Here is my current configuration after tweeks based on what you provided:
Hardware Version   RBR20 + (2) RBS20
Firmware Version   V2.5.1.16
GUI Language Version   V1.0.0.375
Operation Mode   AP
RegionNorth America
2.4G ChannelAuto ( 4(P) + 8(S) )
2.4G ModeUp to 400 Mbps
5G Channel36(P)+40+44+48
5G ModeUp to 866.7 Mbps
Wireless Network
2.4GHz Channel:Auto
5GHz Channel:36
Security OptionsWPA2-PSK [AES]
Latest test result (20:02 Jun 24, 2020)
From the RBR20 Speed Test
DOWNLOADUPLOAD
813.47Mbps931.97Mbps
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID BroadcastTrue
Enable 20/40 MHz CoexistenceFalse
Enable WMM (Wi-Fi multimedia) settingsTrue
CTS/RTS Threshold (1-2347)2347
Preamble ModeShort Preamble
Transmit Power Control100%
Advanced Wireless Settings (5GHz 802.11a/n/ac)
Backhaul Topology
Enable Daisy-Chain TopologyFalse
Enable Implicit BEAMFORMINGTrue
Enable MU-MIMOTrue
Enable Fast RoamingFalse
A definite improvement, but I'm hoping there is something else I can try to boost it more.  Is there hope?
Message 5 of 10
Guru
Looks like you have made the improvment. If your ISP speed is to spec now, then this is what you should see from now on.
I would make a backup configuration to file. Also mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 6 of 10
maortiz1969
Tutor
I'm not an expert and I do appreciate anything that adds to my knowledge.  Can you please clarify: what I am now getting is all I am going to get?  My ISP is 1Gb/1Gb and my desktop using an ethernet cable get's almost the full 1Gb download throughput.  Is this Router only capable of giving me 215Mb?  Or is the current WiFi technology only capable of that?  Again, I ask in order to learn.
Message 7 of 10
Guru
Wired connection thru the Orbi with a PC should see near 900Mpbs. Wireless will be depended upon your wireless devices and what they support, desiged for and what they connect with the RBR.
Even with a AC 5Ghz supporting link rate at 866Mpbs, this is a link rate only, not a thruput speed so wireless devices may max out at around 400-500Mbps on the down while others may max out at lower rates. I have a Galaxy Tab S2 that mostly maxes out at around 200Mbps. Usually see around 150Mpbs on average. Just what the pad was designed for and rated at when it was built.
Message 8 of 10
maortiz1969
Tutor
Ok, I understand now.  Thank you soooo much for your help, patience and explanation!  I am very happy with the resolution!
Message 9 of 10
Guru
Enjoy. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2719 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
