- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBR20 latest firmware update V2.6.2.104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 latest firmware update V2.6.2.104
Ok. Not sure if or when NG will bring out someting for the RBW.
I'd try the RBR alone with out the RBW and see if the problems continue or not.
Try disabling DST.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do, and thanks again for the assistance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
By the way, for those folks still running V2.6.2.104 on their RBR20, I decided not to do a factory reset. But I did downgrade the RBR20 firmware from V2.6.2.104 to V2.6.1.36 and all of the issues that I was having (intermittent dropping of internet access) went away. I left V2.6.2.104 running on the satellites, however. Again, I'm no longer having any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to upgrade the RBS to same version of FW as whats on the RBR. IF that still doesn't work, you might want to downgrade the RBR to v2.6.1.36 and mentioned by chrisgoodson1 . I would factory reset and setup from scratch as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya they need to be on same version for the most part.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My rule with routers is to NEVER upgrade the firmware - every router I have ever had (multiple manufacturers) gets broken by bad firmware updates - seems manufacturers either don't test, or purposely build bad code to get you to buy new equipment. Most blatant example I had was with Linksys - a final update broke it completely. When I called Linksys, they said to buy a new one - I got open source firmware and the router worked another 3 years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never updating means never fixing security holes...your network must be air tight for that rule. Good luck.
- « Previous
- 1
- 2
- Next »
