- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 no ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR20 no ethernet
My RBR20 ethernet port has stopped working. what other router (upgraded) can i purchase to replace it and will work with my current satellites? CBR40 & RBS40V, or can i only use another RBR20?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 no ethernet
You could use a RBR20, RBR40, RBR50
They'd all work.
All the ethernet ports quite working on your rbr? Just the wan port? just the lan port?
Did you try a different cable?
Different pc?
are you able to log into the router and check its wan/lan port statistics
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just the Lan port quit working. it has internet, and all the satellites work and everything works wirelessly, but no output from he LAN side on the router.
the RBR20 only has the 2 ports, 1-Wan and 1-lan
connected a different laptop directly to the router and get nothing
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd take a little light/magnifying glass and take a look at the pins in the port. I've seen them bent and not work
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
