- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 regularly drops internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 regularly drops internet connection
Are wired connections also dropping connections as well?
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
@etroutsky7 wrote:
To reconnect, I reboot manually or remotely. It will reconnect after going through that process, but this process will happen numerous times/day. Any recommendations?
Could you please explain more about how you reboot the Orbi remotely? It seems inconsistent with "losing internet". We have several posts going about Orbi's Domain Name Service (DNS) process failing.
The next time this happens, it would be helpful to the discussion if you could do a couple of quick tests:
- Try to connect to some resource using the IP address rather than the domain name.
Such as ping 1.1.1.1 or ping 8.8.8.8 - Then try to ping using the domain name
i.e. ping one.one.one.one or ping dns.google - Rather than reboot, first try to "Test" the internet connection
On the Orbi web interface, select the "Internet" menu item, then up at the top of the screen, click on the "Test" button.
This may take a few seconds, but not nearly as long as rebooting.
If the "ping by IP" works, but the "ping by name" fails, this is evidence that the internet connection has not dropped, but that the Orbi is no longer resolving names. (The subject of those posts.)
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. I have no wired connections.
2. Firmware: .26. I’ve seen in posts that .30 and .36 are available. I have checked for updates through the app. It won’t update.
3. I have not attempted to log into the network through my laptop. I will try this.
4. Home is 5K sq ft, tri-level home. Router is on lower level with a satellite on each of the upper levels. Based on 9 foot ceilings, the furthest satellite is less than 30 feet away from the router.
5. What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- Hmmm. This is where you start losing me. I believe I’m on auto. How do I switch to MANUAL?
6. Any Wifi Neighbors near by? Approx 10
7. When you started into the next section on Beamforming, my brain just exploded. Yeah. No idea🤪😂
8. Has a factory reset and setup from scratch been performed since last FW update? No. Nor do I know how to do that. Sorry, master Jedi. I’m not a very good apprentice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
any thing closer than 30 feet is too close.
Use a wired PC or laptop and a web brower to connect to the RBRs web page at 192.168.1.1 or orbilogin.com. Make any changes as suggested here.
If a reseis needed:
https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
@etroutsky7 wrote:
Thanks so much for all your help! I understood about 1/3 of what you said. Tech is not a strong point for me. I will attempt to implement the things you mentioned and get back to you. Here are a few initial responses to your questions. Unfortunately I may end up being an exercise in patience for you. My apologies in advance…
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does that work for you?
