Orbi WiFi 7 RBE973
Reply
RBR40 Connection Issues
A_correa4
I've been having issues with my Orbi RBR40 Units with 2 satellites since I've bought them in Dec. It was purchased brand new from Best Buy, and after installation everything ran smoothly. Maybe a few days later, I noticed the signal dropping off every 24hours or so. The satellite locations are no less that 500 ft away. I constantly have to restart Orbi hub and it get it working fine again. Until another 24-48hrs where the same issue occurs. What can I do? The satellites flash orange or pink
Message 1 of 5
A_correa4
Re: RBR40 Connection Issues
All setting were left at default. I already reformatted units back to original and keep them thinking it would solve the issue. But it did not
Message 2 of 5
Guru
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Message 3 of 5
A_correa4
I use Comcast and get 160mbs. My modem is a Netgear CM1000 docsis 3.1
I have a small 2 bedroom home no more than 1000 square ft. I have one satellite in the garage and one in the front room of the house.
Its default settings, so I'm assuming channel is auto. I can try to switch it and see if that works.
Thanks for help.
Message 4 of 5
Guru
For a 1000sqft home, you have the base and two satellites running? You should only need the base router and maybe the one satellite out in the garage at 30feet in between minimum.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1351 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
