- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR40
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Try this aswell:
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
