× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR40
mcdonaldd
Follower
RBR40
Just upgraded to AT &T high speed which it works when im on AT & T, but when im in a different section of my house and connected to Orbi the speeds are super slow
Message 1 of 2
Guru
Re: RBR40
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is the Orbi system operating in Router or AP mode?
Was this happening before you changed your ISP?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 385 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
