Orbi WiFi 7 RBE973
Reply
RBR40
GSzab
RBR40
Just did the lates firmware update and one of my satellites did not update and will not connect any advice.
Message 1 of 5
Accepted Solutions
Guru
Re: RBR40
have you tried hardwiring the satellite into the router?
Then trying the update/sync?
Message 4 of 5
All Replies
Guru
Re: RBR40
What version had been loaded?
How did you update the RBS? RBS should be updated first, then update the RBR lastly.
Message 2 of 5
GSzab
Re: RBR40
Currently running V27.4.24 on the base and one satellite while the other satellite is still on the old version v7.3.22 and will not update  I tried rebooting and did not work the one rbs20 will not connect .  I logged on to the app this morning had a message to update firmware and clicked update.
Message 3 of 5
Guru
Re: RBR40
Message 4 of 5
GSzab
Re: RBR40
Yes and tried a hard reset also now it will not recognize the satellite unit or even sync up.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 970 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
