- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Drops after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I just updated the firmware in my RBR50 to V2.7.2.104. After this, my internet connection frequently drops. I didn't have this issue before the firmware update. The update was successful. If I power cycle the orbi, it will work again for a few minutes to a few hours and then loose connection again. It's not my ISP. I see several other posts over the years for similar issues, but no solution. Any ideas? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Drops after firmware update
Also what is your NTP settings configured for? What time zone are you located in?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having same issue. Seems to impact the router and drops internet, but devices stay connected.
I've confirmed its not ISP service not my netgear modem. Instead of powercycling the Orbi RBR50, I login into the GUI (not the app) and "test" the internet connection and it revives relatively quickly. If I'm not at my desk, I'll reboot it from the app. Its about 5 times a day for me.
Nothing obvious from the logs, but its been a PITA to figure out the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ngautobot wrote:Hello,
V2.7.2.104 is faulty.....revert back and wait until things get sorted out
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the past two weeks, the RBR50 keeps dropping my internet connection. My AT&T router allows me to connect with max speeds but only when I'm closer to the router. Netgear/Orbi - you've got a problem it appears. My Orbi Wifi has been SOLID for 3 years up until the past two weeks and the latest firmware (V2.7.2.104)got installed. 😞 😞 😞 YES, if I restart and reset the RBR50 router, it will reconnect but then within a couple of hours, it will disconnect. NOT GOOD!!!
My family and I am really getting frustrated!! HELP!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DJMarc127 wrote:For the past two weeks, the RBR50 keeps dropping my internet connection. My AT&T router allows me to connect with max speeds but only when I'm closer to the router. Netgear/Orbi - you've got a problem it appears. My Orbi Wifi has been SOLID for 3 years up until the past two weeks and the latest firmware (V2.7.2.104)got installed. 😞 😞 😞 YES, if I restart and reset the RBR50 router, it will reconnect but then within a couple of hours, it will disconnect. NOT GOOD!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I rolled back the firmware. I also ended up swapping out my old comcast cable service for att fiber. The att modem has its own router, so by RBR is now in AP mode. No issues now, but its also not doing the routing work, just the wifi work.
Curious to me that on the RBR GUI its doesn't say to update the RBSs first--but its plain as day in the manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next time try disabling Traffic Meter if your using it or DST. Others reported this solves the problem on v104.
@andybrwn wrote:So I rolled back the firmware. I also ended up swapping out my old comcast cable service for att fiber. The att modem has its own router, so by RBR is now in AP mode. No issues now, but its also not doing the routing work, just the wifi work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Next time try disabling Traffic Meter if your using it or DST. Others reported this solves the problem on v104.
Doubtful
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ngautobot wrote:
Yeah, it's got to be the firmware. This newest version is completely buggy. Everything was perfectly fine until I updated the firmware. It's not in any other settings. How do I revert back to a previous firmware version?
If you've already tried all the great suggestions on how to fix the problem, yoyu can go to the download section, enter your model number and see what's there.
Good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:
another over-riding post...thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before reverting the firmware, you should try to disable "Traffic-Meter" -> a know bug with the firmwarfe (not only 2.7.2.104 !!)
Disable "Traffic-Meter", see:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disabling the Traffic Meter on the app, seems to have taken care of the periodic dropping of service. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
NG is working on a fix. Theres seems to be a beta v105 out there that someone got from NG. Seems to solve all this. Hopefully NG will get it released soon.
Thanks for letting us know.
@DJMarc127 wrote:Disabling the Traffic Meter on the app, seems to have taken care of the periodic dropping of service. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
What did you roll back to? Does anyone know the most recent stable version? I'm having all kinds of issues over here and that's after doing a factory reset on the router and all satellites and before going to V2.7.2.104
- Mark as New
- Bookmark
- Subscribe
- Permalink
What kind of problems are you having?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling the following and see if any of these are enabled:
Armor, Circle, Traffic Meter. Daisy Chain, and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Try reverting back to v16 as last resort.
@MyriadRocker wrote:What did you roll back to? Does anyone know the most recent stable version? I'm having all kinds of issues over here and that's after doing a factory reset on the router and all satellites and before going to V2.7.2.104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Satellite that previously always had a solid 5Ghz connection to the RBR50 only connecting via 2.4Ghz with a "Poor" backhaul status. Satellites dropping connection all the time, disappearing from the GUI randomly. My system was fine on a previous version of the FW. I just don't remember which version it was. That's why I asked what they rolled back to. I've read and read and read on the forums here. I just want to get back to where I was before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then you can revert back to what had worked for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's my intention, but also why I asked what they reverted back to. Since I did the factory reset and all that, I don't recall what version of the FW I was running then. It's been a few weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's receommended after every firmware update to "reset" the satellites. To do this, you need a paper-clip.. insert it into the hole next to the LED light on the back of the satellite.. hold it in for 20-30 seconds until the LED turns yellow and starts blinking.. release it.. then let it normally boot-up (i.e. blinking white light onhte font of the RBS850) and let it connect to the RBR850 (i.e. when you see as olid "blue" light).
You may also need to re-"sync" the RBR850 and RBS850s. Use the "sync" button on the other side of hhe RBR850 and RBS850 for this purpose. Press and hold the "sync" button on the RBS850 satellite, then you got 2 minutes to do the same on the RBR850 main router ro access point. These buttons are sorta hard to press so be sure you press it firmly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pressing the reset button is only needed for 15 seconds. No longer.
