- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Firmware Update & Documentation
- Mark as New
- Bookmark
- Subscribe
- Permalink
having issues with WiFi connectivity since updating the Orbi to 2.5.0.38
i see that there is a HotFix 2.5.0.40, per the docuemntation it states:
To manually update your satellite’s firmware:
1. Launch a web browser from a computer or mobile device that is connected to your
Orbi network.
2. Enter orbilogin.com.
A login window opens.
3. Enter the router admin user name and password.
The user name is admin. The password is the one that you specified the first time
that you logged in. The user name and password are case-sensitive.
The BASIC Home page displays.
4. Select ADVANCED > Administration > Firmware Update > Manual Update.
The Firmware Update page displays.
5. Select the check box next to your satellite’s model name.
6. Click the Update button.
The Orbi satellite Firmware Update window opens.
I dont see anywhere in the App Advanced > Administration. Anyone else having issues?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need to use a PC and web browser to log into the RBRs web page to find the FW update section there.
Also it's recommended to factory rest and setup from scratch after loading FW if problems are seen after FW updates are applied.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Firmware Update & Documentation
Thanks, i'll give it a try this evening. I'll update once completed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
