JDZSB's avatar
JDZSB
RBR50. Not connecting to internet.
I have a RBR50 router and satellite which has been working extremely well up to now. I came back from a week off and the WiFi in the house will not connect from the Router through the cable modem to the internet. I keep getting strange messages that the hardware certificate has run out or the orbilogin website is an invalid website. Something is wrong but it is over my head. I cannot get ahold of anyone at NetGear to even ask a question as to what to do next. The COX tech team tells me the modem is working perfectly, I have WiFI in the house, but cannot get the router to connect through the modem to the internet.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to factory reset the orbi unit and tried to use another web browser when accessing the orbi GUI?
    DarrenM
    • JDZSB's avatar
      JDZSB
      I finally figured out that the problem of not being able of getting on the internet was with the system. There was a firmware update to the RBR50 of which I was not aware of which was due to a hacking problem uncovered by someone who does that for a living to help out manufacturers. I had been trying to figure out what to do using my ipad which NetGear did not recognize for the orbilogin website. I had to get on my home computer which I had used for the original set up. When I did that it required me to log in as the admin and my password used when setting the system up originally. Once i got on the computer, and was prompted to login, it then authorized the use of the system with the new firmware. I never received an E-Mail or any notice of the issue or the corrective action, which was not a good practice by NetGear.
