- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 (Orbi Router) Firmware Version 2.7. 2.104.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it safe to download the latest firmware version (2.7.2.104). Reading on comments in the community and online, there are some bugs in it. Please help....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 (Orbi Router) Firmware Version 2.7. 2.104.
IF yoru system is working. Keep what you have. If you do decide to update. Manually download and manually install the FW. Power OFF the system for 30 seconds then back ON. Don't update using Orbi app.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/m-p/2055212
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2028357/high...
https://community.netgear.com/t5/Orbi/New-Orbi-RBR50-Router-Firmware-Version-V2-7-2-104-Released/m-p...
Good Luck
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Stallion69,
I've upgraded to .104 about a week or two after its been released. No issues whatsoever.
Based on the release notes it addresses security vulnerabilities. So it's ultimately your decision if you want to keep your network secure or not.
https://kb.netgear.com/000062857/RBR50-RBS50-Firmware-Version-2-7-2-104
Anyways you can downgrade anytime you have issues with .104.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ORBI is working fine right now. But I think I will upgrade it the way u mentioned instead of the APP.
My neighbor has the same ORBI and she has it somehow set up where it upgrades automatically through the ORBI App. It’s been running fine so far for her.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, you can keep whats loaded for now as well if it's working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I will for now. Thank you very much....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
