Orbi WiFi 7 RBE973
Reply
RBR50 PORT forwarding issue
rtparies
Guide
Hello i am having issues with port forwarding .
I have a bunch already configured ( see image)
i am trrying to add a new forward using port 22
i get the error
The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type
As you can see from the image i am NOT using that port
Thanks for any help
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: RBR50 PORT forwarding issue
Hmmm.  A puzzle.  When the message is scrolled, it lists a whole bunch of stuff to examine.
Do you have Remote Management turned on?
Any Port Triggers?
Any Services forwarded?
Having "literally nothing" set up on this page, I set up forwarding on Port 22, and it worked just fine.  Maybe someone with more experience has a suggestion for what to look at.
Message 2 of 3
rtparies
Guide
thanks......      i forgot to look at port triggers.....  DUH!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 568 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
