jdewitt2024
Dec 18, 2023Aspirant
RBR50 Satellite Dropped Connection and will no longer connect to the router
I have used my Orbi RBR50 pain free for years. Just today the satellite disconnected from the router and it will no longer connect. I've tried hard resets, moving it near the router, and the synch process (reboot router, synch on router, when blinking synch on satellite). The satellite just blinks white and does not connect to the router. Any other suggestions?
What FW versions are loaded on the RBR and RBS?
Did you reset the RBS and RBR and setup from scratch?
Did you use the RBRs Add Satellite wizard to see if it will re-add it?
Possible the RBS maybe going bad.
- jdewitt2024Aspirant
Version: V2.7.4.24 for the router, The RBS will not even appear in the admin
I have used the set up wizard several times, no luck. I have also reset the RBS. The whole reset I need to plan when family not using it for work or school.
Try the RBS ethernet connected to the back of the RBR and see if it gets an IP address and appears on the RBRs web page...
