- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Second hand purchased, how to register
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi just purchased an Orbi RBR50 with satelite second hand. I have tried to register but it says the product already registed. I have sent an email but no reply as yet. I was hopping someone inthe community would be able to help me. Maybe I don't need to register to use the system? Any help would be great. Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Second hand purchased, how to register
Thank you have sent message, but no reply as yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've seen theres alot of people with the same issue as myself. Does anyone have an answer and can I just use my router and satelite units without registering them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can use the system with out registering the system. Just walk thru the setup wizard or you can configure the system manually your self. Use the installation guide and user manuals for more help and information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's great info. That was what I was looking for. Thank you so much. Will try and get set up. Wish me luck. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All sorted, up and running and very good wifi. Thank you very much for your time and your help. Stay safe and take care.!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know.
Be sure to do a back up configuration to file for safe keeping on the RBR. Saves time if a reset is need.
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
