- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Solid Magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR50 Solid Magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Solid Magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Coztim wrote:
Internet stopped working all of the sudden. RB50 Solid Magenta. Contacted ISP, went through all their troubleshooting and the connection to modem is good (tested with direct either to laptop). Reboot of RBR produced same results over and over - blinking white, followed by pulsing white, followed by solid magenta. After reading some posts decided to reset to factory. Reset RBR and RBSx2 no issues, blinking amber, now solid green. Reboot of RBR produced same results - blinking white, followed by pulsing white, followed by solid magenta. Any help or suggestions would be greatly appreciated. Thanks, Tim
If you are getting an internet connection, connected directly to your ISP modem/router, have you rebooted that device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if you mean the modem, yes. Thankfully I kept my old EERO system and it came straight up (wifi everywhere). Since then I have tried to bring my Orbi system back up two times with no luck. Disconnect modem, reboot modem, follow Orbi intitial install instructions. Each time same thing, flashing white, followed by pusling white, followed by solid magenta.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Coztim wrote:So if you mean the modem, yes. Thankfully I kept my old EERO system and it came straight up (wifi everywhere). Since then I have tried to bring my Orbi system back up two times with no luck. Disconnect modem, reboot modem, follow Orbi intitial install instructions. Each time same thing, flashing white, followed by pusling white, followed by solid magenta.
So you've done a factory reset and it did not fix it. How exactly did you perform the factory reset?
Have you changed the network cable connected from the ISP device to your Orbi router?
Did you reboot the device that your Orbi router is connected to?
Is your Orbi router setup in router or AP mode?
Are you using ISP provided DNS servers or did you choose to use your own DNS?
After you reset the router, did you perform an install as if out of the box?
