Orbi WiFi 7 RBE973
Reply
RBR50 and AT&T conflicts
DaveMo
Follower
I have struggled over and over to get my Orbi to work with AT&T fiber. Can anyone provide a simple to understand step by step way to get the entire system to work together without 404 errors or devices needing to forget Wi-Fi and then resign in?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
SW_
Prodigy
Prodigy
Re: RBR50 and AT&T conflicts
As a starting point, check out this thread. If you're still having problem, come back here with more specific problem description if possible.  Good Luck!
Message 2 of 3
gr8sho
Virtuoso
The best advice here is to setup the RBK50 as an access point. Leaving the WiFi on the gateway enabled is up to you as the Orbi can handle the traffic better.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 454 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
