Orbi WiFi 7 RBE973
Reply
RBR50 and CM1150V compatibility
Windchaser
Tutor
Hi, I am new to Netgear community.   I also posted this within the CM1150V discussion group.
Six months ago I upgraded my network with the Orbi RBR50 and it was attached to the Comcast modem.  We have Comcast "Blast" service and we were getting 150-170 mbps download and 12-15 mbps upload.  All was good in OZ.
Last week I upgraded to the CM1150V to get rid of the monthly modem fee.  When my iMac is connected directly to the CM1150V I get 150-170 mbps down and 10-20 mbps up....HOWEVER, when I connect the CM1150V directly to the Orbi RBR50, the speeds drops to 50-70 mbps down and 11-12 mbps up. This speed is consistant when testing the other satellite units within the house too.  The phone service is working OK.
I purchased the Netgrear units to avoid compatibity issues and simplify the installation.  I went for the CM1150V to be "future proof" with the trend to DOCSIS3.1
Now I wondering if the newer DOCSIS 3.1within the CM1150V is not compatible with the DOCSIS 3.0 in the RBR50?
Firmware for RBR50 is V2.2.1.210
I greatly appreciate any insights on how to resolve this issue.
Message 1 of 5
Accepted Solutions
Windchaser
Tutor
Re: RBR50 and CM1150V compatibility
Thank you ... I completely rebooted the CM1150V, Orbi and the satelites and the network is now back to 180 mbps.
I see where I went wrong, I just turned off/on the Orbi when I installed the CM1150V and did not go through the process of restaring everything from scratch.  Thanks again.
Message 4 of 5
All Replies
Guru
Did you power OFF the modem and reset the RBR router and setup from scratch after powering ON the modem?
When you set up from scratch, don't enable QoS, Access Controls or Traffic Meter just yet.
Test the speeds with a wired PC and web browser or the speedtest.net app installed on the PC first.
Be sure to swap lan cables between the modem and RBR. CAT6 is recommended.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 5
ekhalil
Master
Have you followed the instructions in the manual to connect the cable modem to a router as follows:
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 3 of 5
Windchaser
Tutor
Message 4 of 5
Guru
Glad you got it working. Yes, when chaning Modems or routers. It's always best to power both systems Down, make ths change and then power the modem on first, then router.
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3211 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
