× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR50 can't address outside 24 bit range for port forwarding.
greypanda
I have set the IP address and Mask to 172.16.0.1 255.255.240.0. Everything works OK, but I can't port forward to anything past 172.16.0.255, i.e. 172.16.1.77. It only allows a zero in the third octet.
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: RBR50 can't address outside 24 bit range for port forwarding.
Netgear does not support subnetworks larger (different) than 255.255.255.0 respectively a max of 254 workable hosts. Said but true.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
CrimpOn
Guru
Thanks for posting this.  What a hoot!  The Orbi "takes" that subnet, and when parameters are communicated with DHCP, that subnet is provided. (Verified with Windows 11.)  My guess is that this allows users to create a huge LAN subnet, but I am 90% certain that no other part of the system will accept an IP address outside the base 255.255.255.0 subnet.
(Not LAN assignments, not port forwarding, not filtering, blocking, etc.)
I also have real doubt that WiFi clients outside the regular subnet will be able to communicate with devices in this expanded subnet.  Doing an experiment on this would require setting a static IP on something before connecting to the Orbi WiFi.  (Not sure if I have enough fascination to do this.)
Message 3 of 4
greypanda
thanks, everyone. Indeed, wireless clients also fail that way.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 518 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
