- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 connection issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi needs to be reset 1 to 4 times a day. It seems to start this after a small power outage or I have turned it off for some reason.
After a couple of weeks it seems to get better until the next episode.
I have done firmware updates and did a factory reset without any results. Also done numerous power recycles with modem.
It may be a coincidence, but these problems seem to have started when i tried the trial version of Armor Security. The month I trialed that it started to be reset everyday. It has continued after the trial and is no longer being used.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 connection issues.
I have an RBR40 and am running into a similiar issue. For the last week, the router decides to stop working at random intervals. Probably 2-3 times a day. My devices appear to be connected to the network, but they are unable to connect to the internet. When this occurs, I cannot log into the router using either 192.168.1.1 nor can I connect via the mobile app.
This issue affects both wifi and wired connections.
I have not tried doing a factory reset, yet. I will probably try that next. I do have the latest firmware installed.
Please help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the back reset button for 15 seconds then release.
@gpeck54 wrote:Orbi needs to be reset 1 to 4 times a day. It seems to start this after a small power outage or I have turned it off for some reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the current version of Firmware for the Orbi. My modem is a Arris Surfboard SB8200 recommended by Atlantic Broadband which is my cable provider.
WiFi is just a appliance like the refrigerator anymore. If it was not working well I'm sure I would be lost.
I changed everything on your list I could find under Routerlogin advanced settings. I put channel to 11 instead of auto. I enabled Beamforming and MIMO. I disabled Daisy Chain. I couldn't find how to disable the other items. Also i set the preamble to short.
I have had to reset router 3 times in the last 12 hours. Am at a loss.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would open a support ticket with NG support and ask for additional help and information. Might ask about an RMA as well.
https://www.netgear.com/support/#
Good Luck.
