- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 gets 900Mbps ethernet to PC, RBS50 gets 400Mbps ethernet to same PC
All the advice in this thread is wrong.
If your satellite is connected via wireless backhaul, what you're experiencing seems normal.
If you connect your satellite to your router via a CAT6 Ethernet cable, you'll get the full speed you want.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@aakshey wrote:All the advice in this thread is wrong.
What do you think of connecting the satellite and router via a powerline connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
In theory the wireless backhaul can go faster than direct gig ethernet - all dependent on your environment. Of course, the reliability of wired is going to be MUCH higher. Now Powerline is NOT the same as ethernet. It is still dependent on the electric grid in the home.
I say go to your local electronics store and/or favorite online retailer and get a Powerline pair and test:
- Orbi Router - Powerline - Powerline - TV/Devices
- Orbi Router - Powerline - Powerline - Orbi Satellite - TV/Devices
In option 2, the Powerline is used as the backhaul and hence make sure you have it connected to the correct port in both the router and satellite. Your rooms are really close though, so you may get better throughput through the wireless backhaul.
Due to the size of your home, I am not convinced you need the satellite and hence I personally lean towards option 1. With that being said, if all of your devices have wireless options, you may not need the Powerline either.
As you can see are a lot of factors at play, so test a lot. Networking is a combination of science but can be an art too. What works for another, may not work for you and in your home. Let the fun begin 🙂
Validate the return policy when you purchase. If Powerline does not meet your expectations, take them back within the time limits of the return policy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will be worse than WiFi backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In a 800 sq ft home, a single Netgear X4S will work better than RBK50. Just place centrally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A little weird I know, both bedrooms have cable hookups but living room nothing. Just trying to find a solution with what I got. without rewiring or routing new lines.
Another curve ball is my PC does not have a wireless adapter, only an Ethernet network card.
I like the idea of the orbi satellite located behind PC and plugged in Ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Run an external CAT6 wire along your wall. From the router to the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All?
Perhaps....the OP should really look clser at the FW. The rest will take care of itself. Once its stable, stand back and leave it alone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All?
I downgraded to firmware 2.3.5. First on satellite, ran a speed test, then downgraded on router, ran a speed test. Wired speed stayed the same, consequently wireless speed actually fell by a lot. Upgraded back to newest firmware, wifi speeds are back to normal.
Thanks for the suggestion. Next I am going to try a powerline device.
- « Previous
- 1
- 2
- Next »
