- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 hardwire works device don’t have internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Community. I have the orbi RBR50. Have had it for several years. Internet provider is verizon. Ove the last several months have to reboot the verizon modem at least once a week. My hard wired devices into the orbi work fine, but my WiFi device show connect to WiFi but cannot get any content. States no internet. Been looking for a solution through varies forum but cannot find any. Any help would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 hardwire works device don’t have internet
What wireless devices are you using>
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Traffic Meter, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
