Orbi WiFi 7 RBE973
Reply
RBR50 intermittent DNS lookup issues
DavidDaly
Initiate
Re: RBR50 intermittent DNS lookup issues
I'm willing! I sent a private message.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 51 of 135
Guru
What happens if the DST is enabled? Does the problem re-appear?
@alokeprasad wrote:
Does it matter that my Orbi is 1 hr behind?
It is not set to adjust for DST automatically and did not.  It has been working fine.
Message 52 of 135
Brentx
Tutor
Sure... but should I have done that prior to calling support?  Is that the new standard... Hunt and peck around for their issues they introduce?  Imagine all the old folks getting fleeced by them because of people who call in first..
Message 53 of 135
vajim
Master
help is here
@ChristineT
Message 54 of 135
alokeprasad
Mentor
I never had any problems w DNS so I am reluctant to change any settings. I need my network for work and Netflix!!Smiley Happy
I really don't care if the Orbi's clock is off by 1 hr.as long as all my devices are able to resolve names.
Message 55 of 135
kevindubs
Star
I've had DST enabled after factory reset.
It's been about 23 hours now, with no issue.
Message 56 of 135
vajim
Master
nice....good luck
Message 57 of 135
archp
Star
No factory reset here. This is what I did so far, around 4pm Yesterday, I did the following:
Turn off dst, (live in Cali, so changed time zone to Alaska), pointed ntp server to pool.ntp.org.
So far no disconnections, will update if it goes a full 24 hours.
I also emailed the engineering team all my details as well. Will keep you all posted when I hear back.
Message 58 of 135
Guru
Sounds good, keep it going for now.
Mines enabled and set to actual time zome. No issues thus far.
Message 59 of 135
vajim
Master
but yours was never broken
Message 60 of 135
AnOrbiUser
Same issue here -- the following has been happening for a few days now:
1)  At least once every 24 hour period all of my 56+ devices (smart house) are no longer able to find internet -- note the wifi signal is fine and my LAN works great
2) Manually configuring a device with DNS works around the issue entirely, but practically I can't configure DNS for all of my smart devices
3) Resetting the RBR50 or even just pressing the "Test" button in the Internet Setup page in the Admin interface resolves the issue for another ~24 hours
I updated the firmware yesterday to V2.7.2.104, but no change in behavior. I would very much like to avoid a factory reset, so I am trying the NTP server change and disabling DST as suggested by others here.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 61 of 135
riegelj
Initiate
I was abble to reproduce the problem with debug enabled. Log files have been set to the engineers.
Message 62 of 135
vajim
Master
thanks...that would be like the 'firmware'  engineers.
Message 63 of 135
mwhold11
Tutor
I have been experiencing internet connectivity issues and initially thought it was my DSL.  After troubleshooting and researching online I used telnet to connect to my Orbi and discovered that dnsmasq was not running which explained why DNS lookups were not running on my system.
As a workaround I created a cron task to run a bash script which uses the ps command to check whether dnsmasq is running and forces a restart if it is not running.
The steps I performed are outlined below:
1. Enable telnet mode using http://X.X.X.X/debug.htm where X.X.X.X is the IP address of the Orbi router.
2. Telnet into the Orbi router.
3. Create the bash script using the following command:
    echo 'DNSSTAT=`ps|grep -c dnsmasq`' >/tmp/dnsmasq-test.sh
    echo 'if [ $DNSSTAT == 1 ]' >>/tmp/dnsmasq-test.sh
    echo 'then' >>/tmp/dnsmasq-test.sh
    echo '/etc/init.d/dnsmasq restart' >>/tmp/dnsmasq-test.sh
    echo 'fi' >>/tmp/dnsmasq-test.sh
4. Make the bash script executable using the following command:
    chmod +x /tmp/dnsmasq-test.sh
5. Create a cron job to run the batch file ever minute using the following command:
    echo '* * * * * /tmp/dnsmasq-test.sh' >>/tmp/etc/crontabs/root
The above steps should force the dmsmasq process to reload and should keep DNS outages down to a couple of minutes until a better or permanent fix becomes available.
Please note that changes to the configuration or reboots of the router will require reapplication of the workaround.
Message 64 of 135
Guru
https://community.netgear.com/t5/Orbi/Alternative-ways-to-troubleshoot-instead-of-just-downgrade-FW-...
Message 65 of 135
chozian
Model: RBK50v2
Firmware: 2.7.2.104
I've been experiencing the same issue as OP starting immediately after the recent time change. Adding a root cronjob that restarts the dnsmasq service every hour has significantly reduced the occurrence of the symptom. I just got done bumping the cron job up to run every 30 minutes. The NTP config change sounds appealing and easy to apply and revert. I will likely give that a shot if the symptom appears again. I reached out to a Netgear admin and moderator via DM to provide my assistance in troubleshooting if necessary. My hope is that they can develop a fix and release a firmware update soon. My next fallback is Voxel's custom RBK50 firmware since the issue has not been reported using it. If all else fails, I'll return my RBK50 to Costco thanks to their liberal return policy.
As previously linked, I found the information available at https://community.netgear.com/t5/Orbi/Orbi-DNS-and-DHCP-and-NTP-Broken-Short-Term-Fix-Options/m-p/20... the most helpful.
Message 66 of 135
mwhold11
Tutor
there was an issue with the first version of the workaround that I posted. An updated version is shown below.
    echo 'DNSSTAT=`ps|grep -c dnsmasq`' >/tmp/dns-test.sh
    echo 'if [ "$DNSSTAT" == "1" ]' >>/tmp/dns-test.sh
    echo 'then' >>/tmp/dns-test.sh
    echo '/etc/init.d/dnsmasq restart' >>/tmp/dns-test.sh
    echo 'fi' >>/tmp/dns-test.sh
    chmod +x /tmp/dns-test.sh
    echo '* * * * * /tmp/dns-test.sh' >>/tmp/etc/crontabs/root
Message 67 of 135
SirVilhelm
Tutor
This is what I did as well, no disconnects so far. Think it's obvious that this is connected to the time change.
Edit: what I did was change the time service to pool.ntb.org and disabled auto daylight saving adjustment.
Message 68 of 135
Coffeecup
Star
RBR50v2
Unsure FW but issues occurred around DST and FW upgrade
Mac Os 10.13.6 High Sierra
xfinity internet
Message 69 of 135
archp
Star
Ok so this seems to be working, 24 hrs and no disconnect.
Glad I didn't waste hours doing a factory reset and spend time reconfiguring.
If a factory reset worked for others, great, if you want an alternative, try the below.
Also that is literally the only thing I did, didn't mess with DNS or anything else.
This did the trick. For those looking
Message 70 of 135
tak1313
Luminary
Could the DNS problem be related to this, considering it's not affecting all units?
https://www.csoonline.com/article/3603929/flaws-in-widely-used-dnsmasq-software-leave-millions-of-li...
I also have an Asus router and noticed their most recent update specifically mentions it fixes the above situation - unlike Netgear that never states what their updates are doing.
Message 71 of 135
tak1313
Luminary
This article also includes OpenWRT as specifically vulnerable (the other article mentions Netgear as a manufacturer.  I believe Netgear routers (among many) is based on OpenWRT?
https://www.helpnetsecurity.com/2021/01/19/dnsmasq-vulnerabilities/
Note- I don't know if this is THE issue, especially since Netgear has the annoying habit of NOT stating what their updates address.  I'm just stating a possible source of the issue.
Message 72 of 135
Guru
Anything is possible. However since some users have disabled DST or made a change in NTP, possible that these two could be related. Seems that for the most part the problem appears to be over after these changes, until the next time we have the time change.
Yes Orbi is based off a build of WRT. If you look at the telnet window when you log in, it gives this information.
Message 73 of 135
vajim
Master
and of course there are generic release notes
Message 74 of 135
archp
Star
This is what the netgear engineer said:
We have identified that the traffic meter will cause problem while auto daylight saving time enabled. Since you turn off auto daylight saving time, the issue should be go away. Turn off traffic meter would also avoid the issue. We are working on a trial fix firmware. Will provide to you once it’s ready. Thanks.
Message 75 of 135
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
