× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR50 keeps failing (wired and wifi connections)
Andre_BR
Hi, I have an Orbi RBR50 and its satellite (RBS50), both with firmware V2.7.4.24, but the RBR50 keeps disconnecting me (becomes unavailable) and the problem is only solved by rebooting it.
It was working fine before my vacations... I have plugged it off from power... 10 days later, powered it on and it is unstable for 2 days.
I have tried to backup config, reset to factory settings and restore config, but it didn't solve the problem.
The troubleshooting options seems to be very limited on this device... Any hints would be really appreciated.
Some additional information:
  • Both wired and wireless connections fail;
  • Only reboot solves the problem;
  • Armor is not enabled.
  • Daisy chaining disabled.
Thanks
Message 1 of 2
KevinLiT
NETGEAR Moderator
Re: RBR50 keeps failing (wired and wifi connections)
Hello Andre_Br,
Welcome to the NETGEAR Community!
I understand that you are having stability issues in your network due to your RBR50.
Please perform a 30-30-30 factory reset on your RBR50 to resolve this issue.
Best,
Kevin
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 321 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
