×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RBR50 low mbps speeds and upload speeds
Jmoreno512
Follower
Hi all- hoping someone can give me some guidance here. My orbi speeds have been horrible I am paying for 500mbps and only getting maybe 250 and also a lot of disconnection issues. Can someone please tell me what my settings should be? Kids are home and I am working from home desperately need the internet to work correctly. Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Mikey94025
Hero
Re: RBR50 low mbps speeds and upload speeds
Message 2 of 3
Guru
You should be seeing this on wired ethernet speeds. Wireless, depends on Mfr of the wifi devices. Most max out  at around 400-500Mpbs on 5Ghz AC mode. Less for older wifi devices.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://https://https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 206 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
