×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RBR50 + satellite randomly disconnecting specific devices from internet
Flibbidyfloo
Guide
I hope someone else has run into this weird problem and can offer some advice, so I appreciate anyone that can help! I'll be as detailed as I can to get started.
We have an RBR50 + satellite set up with over a dozen devices. Nothing at all has changed in the last few weeks, and before that the only change for months was to update to the latest firmware. This problem started on Sunday, March 14th.
Certain devices on the network will suddenly have no internet. They remain connected to the network, and can be seen by the router, showing up as connected in the attached devices list. Once this happens the only fix is to reboot the router.
These devices lose internet, but stay connected to Orbi and show up in the attached devices list:
  • My cell (Samsung) (WiFi)
  • Wife’s cell (Motorola) (WiFi)
  • My laptop (WiFi)
  • Roku, office (WiFi in same room as satellite)
  • Wife’s desktop (wired into the satellite)
These devices do not lose internet:
  • My desktop (WiFi, connects to satellite)
  • Roku, living room (wired into Orbi base station)
  • Camera system (WiFi, connects to base station)
As you can see, it’s a combination of connection types that stop working. Unfortunately testing is hard because if it goes down during the day I have to just reboot it so my wife and I can get back to work. It has only gone down twice so far outside work hours.
During those times here's what I've tried, all with no luck:
  • Checked for firmware update (already on latest)
  • Turn off WiFi on the affected devices and reconnect
  • "Forget" WiFi settings on the devices and reconnect
  • Made sure access control and parental controls are still disabled
  • Tried connecting to the guest network instead - same result
  • Get devices to connect to main router instead of satellite, or vice versa
  • Turn off satellite
  • Reboot just the satellite
  • Release/renew ip, both on devices and on router
  • Enable fast roaming
  • Enable IGMP Proxying
  • Turn off  "Anywhere Access" inside app
  • Changed DNS settings in router to use Google's DNS, just in case OpenDNS was having an issue
  • Manually disabled individual devices inside the app then reenabled them
  • Wait 8 hours to see if it fixes iteself
I can’t think of any other options short of a factory reset, which I can try this weekend, but I’m hoping someone has other suggestions or thoughts as to why this would just suddenly start happening now.
I found an old archived thread on Reddit where someone had what sounded like the exact same problem. One other person replied that they also had the issue, but there were no other replies.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 31
Accepted Solutions
l8nc
Apprentice
Re: RBR50 + satellite randomly disconnecting specific devices from internet
So far, the reports seem to confirm that EITHER turning off DST *or* TM no longer triggers the problem, using the standard graphical interface.
There are other fixes that also work but require debug-level direct access, e.g., restarting dnsmasq (recovers). Note that setting clients to no longer relay DNS through dnsmasq has *not* been shown viable; it would allow clients to continue working using their current DHCP assignment but if dnsmasq crashes then new assignments and renewals would fail.
Message 13 of 31
All Replies
vajim
Master
what orbi firmware are you running?
Message 2 of 31
tak1313
Luminary
That's interesting.  Yesterday (3/18) while I was at work, my wife, who works from home, texted me that we had no internet (her laptops lost internet and her phone which was latched on to wifi at the time).  She did not check anything, as I'm the "computer guy" (SNL reference) for the house.
Within a couple of minutes, she said the laptops were fine, but her phone (only) kept doing the same thing.  I was able to see the various IOT stuff in the house from work (plugs, switches, cams, etc.) so I don't know what else it may have been affecting, or if anything else was affected but by the time I looked at them the problem resolved.
From her description I knew the Wifi worked, since her phone stayed tapped in and didn't hop over to data, but was not connecting somehow to the internet.  At the moment, I feared the dreaded DNS problem, since she described the phone as "reloading" and going through, but constantly happening (but could not describe what error she was seeing).
But all was well even with the phone in another few minutes.  I have noticed over the last couple of days, the signal STRENGTH as viewed by the wifi icon, would drop a little, but I wouldn't lose signal completely, and the icon would show full strength within a few seconds.
hmmm...
Message 3 of 31
l8nc
Apprentice
This appears related to the recent DNS/NTP issue. The router appears to lose the ability to relay DNS requests.
To confirm, try to set the DNS on your laptop or phone to something other than the router.
Here's a link to one of many other threads on this topic:
https://community.netgear.com/t5/Orbi/Orbi-DNS-and-DHCP-and-NTP-Broken-Short-Term-Fix-Options/m-p/20...
Message 4 of 31
Flibbidyfloo
Guide
DOH sorry, the malformed HTML detection on these forums apparently stripped out the line in my original post with the firmware.
Both devices are on the latest, according to the update button: v2.7.2.104
Message 5 of 31
Flibbidyfloo
Guide
@l8nc - This DNS issue would affect only specific devices each time?
Message 6 of 31
vajim
Master
and there lies your problem....v2.7.2.104
Message 7 of 31
l8nc
Apprentice
It would affect only devices that are currently relaying DNS through the router whose DNS is set to 192.168.1.1 (the router).
You can get around this by either restarting the dnsmasq process on the router (as posted to the thread link I gave previously) or setting your device to use some other DNS (e.g., Cloudflare 1.1.1.1).
Message 8 of 31
vajim
Master
Not exactly...I use 192.168.1.1 to get to the router and my Orbi clock / DNS is fine, but of course I'm not running the latest wiz-bang firmware.
Message 9 of 31
Flibbidyfloo
Guide
Ahh, so having my own DNS IP addresses entered into the router itself doesn't automatically set it to that via the router's DHCP like you'd expect?
Ok, I've read the other thread on possible fixes, so I'm going to start with the simplest - turning off the DST and see if that helps. If not then I'll have to switch to my cable modem for DHCP functions.
Though I really don't understand why it wouldn't also affect some devices that don't have a way to manually set the DHCP, like the Roku that's hardwired into it, or the WiFi cameras that don't have any manual setup options at all. Those devices are 100% relying on the Orbi for all DHCP/DNS configuration...
Message 10 of 31
l8nc
Apprentice
There are two outcomes you might expect:
  1. the router provides those DNS IP addresses in DHCP responses
  2. the router uses those DNS IP addresses for its requests, but still tells DHCP clients to use itself (192.168.1.1) as their DNS
NG routers support #2 but not #1 (yet - I hope this might eventually change).
I.e., you can override only the DNS the router sends its queries to, not the DNS the DHCP clients use.
Message 11 of 31
Flibbidyfloo
Guide
So far turning off DST in the NTP screen seems to have resolved the issue - but it's only been a few days, so I'm going to let it ride for a few more to confirm.
Message 12 of 31
l8nc
Apprentice
Message 13 of 31
l8nc
Apprentice
Hi, all,
I confirmed the following with tech support this AM:
- DST and TM interact and crash dnsmasq, killing DHCP and DNS relay
- the current recommended fix is to disable either DST or TM and appears to be stable
- a firmware fix is in the works and will be posted when ready
I also noted the following two issues:
1. IPv6 DNS override does not work; the address entered is not correctly saved in /tmp/resolv.conf as it is for IPv4
2. IPv6 DNS override fields are too narrow (3 characters), though you can just type 4 characters in the fields
3. DNS override on Orbi devices sets the DNS for the router; the DNS for clients (provided in DHCP) is always the IP of the router, not the IP of the DNS; this is a widely-known deficieny in the Netgear graphical interface (there are ways to override via the debug console)
Message 14 of 31
vajim
Master
Did support mention that this DST fiasco appears to only effect those with latest firmware?  I'm on a older version and never blinked an eye
Message 15 of 31
l8nc
Apprentice
There are reports of this affecting other firmware versions too.
Message 16 of 31
vajim
Master
Not mine
Message 17 of 31
l8nc
Apprentice
It does appear the 104 version is much more predictable in how it fails.
If you're running an earlier version, can you please post the following:
- which version of RBR50? (v1 has USB ports; v2 does not)
- which version of firmware on both router and satellite?
- is DST set?
- is TM set?
Message 18 of 31
vajim
Master
- is DST set?
- is TM set?
v2.5.2.4
v1
yes
no
Message 19 of 31
l8nc
Apprentice
If you set DST=yes and TM=no, you're using the fix that we already know works with v104 too.
I.e., your example of using old firmware is NOT shown as an alternate sollution; it uses the same fix.
Message 20 of 31
vajim
Master
Nice
but my firmware never needed a fix for it was never broken
it sounds what you're trying to say is the latest wizbang firmware couldn't handle TM
or....if I set TM on my old firmware there would be hell to pay ???
Message 21 of 31
l8nc
Apprentice
Nice
I don't know; the more recent firmware does protect you better against cyber attacks though.
The only way to know if this woud happen with DST+TM on your firmware is to test; the worst that happens is you lose DNS and DHCP; you can always login to your router, change the settings back, and reboot it to fix.
Message 22 of 31
vajim
Master
@l8nc wrote:
Nice
No to the TM. Not interested
still waiting on the cyber attack
Message 23 of 31
I might honestly just roll it back again. What firmware are you using?
I'm on the latest firmware right now, with DST on and TM off and the disconnects are constant, not intermittent but basically constant on my wifi devices.
Message 24 of 31
vajim
Master
im on 2.5.2.4 but i doubt you can find it available
unless you have a copy of a older version, you might check the download area, enter your model number and see what is listed.
Message 25 of 31
Discussion stats
  • 30 replies
  • 4787 views
  • 9 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
