× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR50
swathi
RBR50
Getting Router not found in Orbi app. Reset the modem but no luck.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Retired_Member
Not applicable
Re: RBR50
don't use the app?
Message 2 of 7
Guru
Re: RBR50
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
What status do you see if you log into the RBRs web page at orbilogin.net?
Message 3 of 7
swathi
Re: RBR50
NETGEAR - Orbi Voice AC3000 Tri-Band Mesh Wi-Fi  is the model.
Message 4 of 7
Guru
Re: RBR50
And is there a ISP modem in front of the Orbi router? If so, what is the Manufacturer and model of the ISP modem?
Message 5 of 7
swathi
Re: RBR50
We have Modem thats provided by ATT.Model is  BGW210-700.
Message 6 of 7
Guru
Re: RBR50
This modem arlready has a built in router and wifi>
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend you try option #3...
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 906 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
