- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50v2 / RBS50 Highly unstable with latest v2.5.2.4 firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR50V2 and RBS50
System is highly unstable with firmware 2.5.2.4 - which is the latest for mass update.
Router stops working ( goes offline) at random times of the day.
Satallites stop working randomly. ( they are on just not working)
Router gets very confused - instead of showing just 2 satallites, it shows 100s of satallites in the firmware page.
Only solution is to factory reset every week and reconfigure. Tried this for multiple weeks.
Anyone else see this poor behavior ? Setup is unremarkable - a single SSID with password. No fancy setup. any suggestions for soltuion ?
Getting ready to throw this out....cannot spend that much time fiddling with this...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50v2 / RBS50 Highly unstable with latest v2.5.2.4 firmware.
You can update to v40:
If your in the US region, you can update to v2.7 version:
I would factory reset and setup from scratch after you load either one of these versions. Update the RBS first then RBR lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if you're certain 2.5.2.4 is not working for you, you may want to revert back to the previous stable version
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updates manually to V2.7.2.102.
Both the satallites and router are still unstable. the router just stops working. Need to power cycle. I will try a factory reset as suggested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@PatG21 wrote:I updates manually to V2.7.2.102.
so when was the last time your system worked with NO problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how the reset goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
- Mark as New
- Bookmark
- Subscribe
- Permalink
