- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS20 won't reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS20 won't reset
Hi - I just updating to the new firmware available for my Orbi system, and for some reason one of my two satellites got messed up. I have tried the 30-30-30 and the regular reset, and I can't get either one of them to work resetting the device. I was attempting to TFTP into the device last night, but all the directions that I can find are written for the router, not the satellite.
Can anyone please point me in the right direction for what to do in order to get this satellite reset?
Thanks in advance~
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS20 won't reset
"messed up"
whats actually going on with the led and the satellite?
have you tried hardwiring them into the router and syncing them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
From what I can see it looks like it keeps boot cycling? I haven't been able to get any devices connected to it.
Satellite from cold boot:
- Blinking white halo, green power LED
- 30 seconds later, pulsing white halo
- 3 minutes later, solid blue halo, but orange icon in app
- halo goes off, but still orange icon in app
- Pulsing white halo, orange icon in app
- Solid blue halo, orange icon in app
- Light off, green icon in app
- Blue light back on
- White flashing halo back on
- White pulse back on
- Light off
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You tried a factory reset?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m on MacOS; is there a guide for using that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
here's a guide someone made for the r7000. should be pretty similar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It can take a few attempts as its sensitive to timings. I've tried up to 6 times before it finally worked. nmrpflash isn't as sensitive but not sure about its working on a mac
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got it - thanks for the background. I will keep working on it and see if I can hit the sweet spot for timing so it starts working.
Would it make sense to attempt to reset the entire system and reload the backed up config file as a bypass for this process?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try resetting but I wouldn't reload a backup config. if the configuration is the issue, reloading it just re-causes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m not sure what else there is to do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try a different firmware in case it was a firmware issue causing it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
