× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBS40 power adapter physical specification
Jjames610
I want to extend the power adapter that came with the RBS40 but am at a loss with the exact size of the plug.  I thought it was a 2.1x5.5 mm male plug but I've order two different ones on AMAZON and the plug will not fit the female sock on the satellite.  I've search on Netgear and on the Community and I can't find any physical specifications on the power adapter.
Can some please point me to the specs?
Thanks,
Joe
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 18
CrimpOn
Guru
Re: RBS40 power adapter physical specification
@Jjames610 wrote:
Can someone please point me to the specs?
I have never found specifications on the Netgear web site for the power plug.  If you come across them somehow, please post.
All the power supplies on Amazon that claim compatibility with Orbi say 2.1x5.5mm plug or say nothing at all.
Message 2 of 18
Guru
Message 3 of 18
CrimpOn
Guru
He has a power adapter. What he wants is an extension cord on the 12v side so the satellite can be placed farther from the electrical outlet while the adapter remains plugged into the outlet.
Message 4 of 18
Guru
So why not put a 110v power extenstion cord on the 110v side of the adapter can call it good? This is easier and less hassle. The 110v side is known style and hasn't changed in moons age. Come in many different lengths and colors.
Message 5 of 18
CrimpOn
Guru
I have used female->male extensions for 12v security camera power.  I can think of some reasons to want a very tiny 12v cable rather than an electrical extension cord:
  • Low voltage cable can be run through walls and 110v extension cords cannot.
  • Esthetics - want to hide the large power adapter and there is no place within 6 feet of the satellite location to do so.
  • Low voltage cable can be easier to hide than extension cords.
It is a big disappointing that Netgear does not publish the specs, just as they do not sell individual power supplies.
Message 6 of 18
Jjames610
That's correct.  I want to put the
RBS40 up on a high shelf and need to extend the 12 v side.  I bought (2) 2.1x5.5 extensions but neither will plug in the router.
Joe
Message 7 of 18
CrimpOn
Guru
time to get out a micrometer and measure the plug?
Message 8 of 18
Jjames610
I thought it was going to be simple.  Someone out there had bought an extension that worked but I guess I was wrong.  Back to the drawing board;-)
Joe
Message 9 of 18
Guru
You can't use a 110v power extension cord?
Message 10 of 18
Jjames610
That's what I'm doing.  It just looks bad.  I wanted to use an extension to run it down the door frame then along the baseboard behind a cabinet to the outlet.
Joe
Message 11 of 18
Guru
What is the color of the paint around the door frame?
Message 12 of 18
Jjames610
White
Joe
Message 13 of 18
Guru
Grab you a white power extenstion cable and some brass screw hooks. Iv'e done this for some LAN cableing I had to run in my pre-existing home. Brass hooks help keep the wire in place and more out of site and makes it look nice.
Message 14 of 18
CrimpOn
Guru
Amazon just delievered my 12v extension cables 5.5*2.1mm:
https://www.amazon.com/dp/B08ZMMJJRF?psc=1&ref=ppx_yo2_dt_b_product_details
(2) for $10.
My calipers measure the stock power supply (male end) at between 5.47  and 5.53mm. This extension cable also measures between 5.47 and 5.53mm.  (My hands are shaky or something.) The stock power supply is plugged into the female end and the male end plugged into my Orbi.  Orbi powered up and I am logged into it.
There is always a chance that Netgear designed the RBS40 to have a different power socket, but the Nerd in me asks, "Why???"  All those Amazon listings say they work with almost every Orbi ever made. Can you give your cables another try?
Harbor Freight will sell a set of calipers for very little.
Message 15 of 18
Jjames610
Thanks.  Have you tried to plug in the male end?  I bought from Amazon two different makes of the same cable in white but could not plug them into the router.  The plug is different though it is  5.5 x 2.1.  The plug has a small center that wraps aroung the center of the female jack.  It will not accept this type of male jack.
I looked at your purchase online and it appears to have the same kind of male plug.
Joe
Message 16 of 18
CrimpOn
Guru
Yes, I unplugged the power cable, plugged the male power cable into the female end of the extension and then plugged the male end of the extension into the Orbi female socket.  There are tiny springs inside the female sockets which require the male plugs to be inserted with a bit of force, and which also 'grip' the plug so it won't fall out easily.
Message 17 of 18
Jjames610
RBS40 Power Adapter PlugRBS40 Power Adapter PlugHi:  I've attached photos of the plug and jack on a RBS40.  Notice the jack is not the same as a normal 2.1X5.5 power jack.
JoeRBS40 JackRBS40 Jack
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 2221 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
