Orbi WiFi 7 RBE973
Reply
RBS40V latest firmware RBS40V-V2.3.0.10_1.0.1 update failure
PB21UK
Tutor
Has anyone tried the latest update, I cant update with this file in auto  update online mode or manually I am at version 08 at present.
Model: RBS40V — Orbi Voice Smart Speaker & WiFi Satellite with built-in Amazon Alexa
Message 1 of 5
Accepted Solutions
PB21UK
Tutor
Re: RBS40V latest firmware RBS40V-V2.3.0.10_1.0.1 update failure
Finally, it went through but showed as failed, I tried a second time and then it succeeded. I updated via the web interface on the router and selected the satellite voice as the one to update but manually. The auto update kept failing.
Message 4 of 5
All Replies
albertkarsa
I am also experiencing the same issue
Message 2 of 5
I completed the update to V2.3.0.10_1.0.1 yesterday.
I just followed the usual strategy.
What happens when you try, and where does it go wrong?
RBS40V Firmware Version 2.3.0.10 | Answer | NETGEAR Support
What Orbi router do you have?
Are you starting the update from the router or from the satellite's graphical user interface (GUI)?
Message 3 of 5
PB21UK
Tutor
Message 4 of 5
That seems to be having a problem all round for different Orbi devices.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3256 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
