- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50, RBS20, ... Network interruption when connection goes from one satellite to the next
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear community,
I'm proud owner of an Orbi system and in general I'm really satisfied with the performance.
One topic bothers me still with the system.
We have 3 floors in our house (cellar, ground and 1st). In the cellar is the Orbi RBR50 connected to a Fritzbox.
From there one RBS50 is connected via LAN cable, an RBS20 is connected via LAN cable and another RBS50 is connected via the specific Wlan connecting Orbi Satellites with the Orbi router.
In the whole home one wifi exists.
Now, when I walk in a MS Teams session on my iphone (or any other device) through the field of any satellite, the connection gets interrupted for a milli second, but long enough to kick me out of the Teams session.
The only thing that I can identify is, that this happens when the MAC Adress my cell gets wifi from changes, so I can see when I leave the wifi circle of one satellite (MAC1) and immediately getting into reach of the next wifi are of the other satellite (MAC2).
I was always under the impression that those interruptions are exactly why I install a system such as Orbi, to not change the network, but remain in the same without interruptions.
Anyone an idea what could change the situation for me?
Best regards
Manuel
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey all, sorry for the late response, I was afk for a while.
Somehow the topic got resolved by itself. I didn´t change any setting, but now I can roam without interruption.
So from my point of view, the topic is solved!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50, RBS20, ... Network interruption when connection goes from one satellite to the next
How many sq ft is your home?
the satellites/router need to be at minimum 30ft apart.
I actually had better service in my home by removing a satellite because they were to close together. I've tested from just 1 satellite to having 4x satellites. 3/4 satellites were to much coverage and devices didn't roam properly. With 1 or 2, it worked the best.
another thing you can try doing if possible is to centrally locate the main router to help prevent daisy chaining. that can add latency and that might be enough to cause drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
The satellites and routers should be more than 30sqft away from each other.
All of the satellites are directly (by lan wire or by bachhaul Wifi) connected to the router, so I do not have a daisy chain setup. 2 of the 3 satellites are even connected via lan wiring to the router, one satellite is connected via backhaul wifi.
All satellites have a pretty good speed,either in 2,4 or (when closer) in the 5Ghz connnection.
The problem is really when I roam from one stallite to the router or the other satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you noticed if its specific to a certain satellite or does it happen with them all?
just wondering about shutting off a couple (for testing) and just use the router and single satellite and seeing how it does. And then if that one works fine, power it off and try the next. Helps to figure out if its a full system issue or just a single satellite issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hm it is technically, whenever I leave the field of one Satellite (or router) and roam into the other field.
So it seems, that the change of MAC Adress of the satellite cuts the connection just for long enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, same with any app that needs always a connection.
Also moves get interrupted briefly (after buffer is consumed) and then restart.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Regarding the fast roaming, where can I activate it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
