- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 Satellite functions but does not appear under "Connected Satellites"
- Mark as New
- Bookmark
- Subscribe
- Permalink
As is shown in the attached screenshot, my two RBS50 satellites show up under "Connected Devices" in the RBR50 admin area, however they do not appear under "Connected Satellites" as expected. Should I be concerned about this? They seem to function just fine otherwise.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you reboot the satellites first then the router do they appear in the connected satellites section?
Try a different browser like IE11 or FF or Opera?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Satellite functions but does not appear under "Connected Satellites"
All devices are using firmware 2.1.4.16
Modem is a Cisco DPC3008
Satellites are on separate floors, probably about 30 feet.
Square feet: 5000+ (A large arts building)
Tomorrow I will try your suggestions about rebooting and using a different browser.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats this art building material made up of if you know?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see any speed drop. Speed is fine. Just the Satellites are not listed where they are expected to be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The building is pretty old. Who knows what is in the walls.
I will say this: initially the Satellites were listed properly under "connected Satellites" and the "Backhaul status" was listed as "good". That was a few weeks ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If things seem good otherwise, I would let it run for now. Nothing to be to bothered by.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a reboot of the router everything seemed to connect fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
