- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 Wired Backhaul Drops and Sat Goes Offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a strange issue that started happening recently... Took a while to figure out what is happening. ~24 hours after connecting wired backhaul the RBS50 will drop offline.
Setup:
RBR50 v1, RBS50 v1. Router mode. 2.7.4.24 FW. (Also tried latest Voxel FW w/ same result.)
Very Basic setup. All defaults, except IPv6 enabled (Open DNS). No NG Armor, no Guest network. About 30 devices connect to the network. No switches on network
Router has two Eth devices connected directly, the rest via WiFi. All devices connect to the Sat via WiFi.
Direct Cat 6e backhaul cable to Eth port 1 on both devices.
Problem:
~24 hours after connecting wired backhaul the RBS50 will drop offline. All devices connected to the RBS50 loose connection. Devices do not switch to the RBR50. The RBR50 and it's devices do not loose loose connection.
To recover connectivity I disconnect the Eth backhaul cable, unplug power to the RBS50 for a few minutes, power up RBS50 and then reboot the whole system from the RBR50 console. The system will reboot with wireless backhaul and work normally until Eth backhaul cable it connected again. Wireless backhaul works with no issues.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Wired Backhaul Drops and Sat Goes Offline
IS that CAT5e or CAT6? There is no CAT6e cabling.
Did you first synce the RBS to the RBR wirelessly, then connect the ethernet cable to the RBS?
Try swapping LAN cable between the RBR and RBS to see if anything changes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @FURRYe38,
Sorry cable is Cat 6 - 50ft.
I did sync backhaul via wireless and let it run for a few days. It consistently has the issue about 24 hours after connecting wired backhaul cable.
House is about 3000 sq ft. Distance between Router and Sat is about 30ft. (3 walls, sheet rock / wood studs). However wireless backhaul works perfectly.
I have not tried another Eth cable.
I have not done a factory reset and setup from scratch since last FW update.
I will try factory reset and setup from scratch next. If that does not work I will buy a new Eth cable to test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: I performed full factory reset and reconfigure of the RBS50 and RBR50. I let it connect via wireless backhaul and run for about four hours. I then plugged in the wired backhaul cable connecting both devices (Port 1 on both). I confirmed wired backhaul connection. It has been running for four days without issue.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
