×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RBS50 pulsing white AND power LED pulsing red. Other RBS50 ok
lbeck02
Guide
I have one RBR50 and 2 RBS50's. Firmware V2.7.4.24. One of the satellites is pulsing white and cannot be synced with the router.  Plus the power LED is pulsing red.  According to the user guide the pulsing red indicates possibly corrupt firmware.  Following is what I've already tried:
  • Reinstalling firmware
  • Resetting with a paper clip
  • Powering on/off 5 times at one-second intervals
  • Moving satellite to another location
  • Swapping the Ethernet cables from the good satellite to the to the pulsing one
I thought that the 5th bullet (swapping the satellites) would show who's bad.  But it didn't. The good stayed good and the bad stayed bad.
What can I try to further isolate the problem?
Message 1 of 7
KevinLiT
Community Manager
Re: RBS50 pulsing white AND power LED pulsing red. Other RBS50 ok
Hello ibeck02,
Welcome to the NETGEAR Community!
I understand that you are not able to connect your RBR50 to your RBS50.
Are you able to connect your PC to the satellite through LAN?
Best,
Kevin
Community Team
Message 2 of 7
lbeck02
Guide
I have 1 Orbi router and 2RBS satellites. I can connect One Sat To The Router But The Other Flashes White And Cannot Sync.
Message 3 of 7
KevinLiT
Community Manager
Hello Ibeck02,
Thank you for your reply!
I understand that you have attempted a factory reset on your RBS50. However, if the procedure is not done correctly then the satellite will not reset.
Please follow the steps in the link below to successfully factory reset your RBS50:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Please let me know if you are still having issues.
Best,
Kevin
Community Team
Message 4 of 7
lbeck02
Guide
Yes.  I did that before I posted here.  I just tried again.  Held the resit in for about 10 minutes.  The ppower button continues to flash red.  I also tried the following without success:
Message 5 of 7
KevinLiT
Community Manager
Hello lbeck02,
Thanks for verifying your troubleshooting steps.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
Message 6 of 7
KevinLiT
Community Manager
Hello Ibeck02,
Thank you for that information!
I escalated your case to our support team.
Best,
Kevin
Community Team
Message 7 of 7
Discussion stats
  • 6 replies
  • 328 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
