Orbi WiFi 7 RBE973
Reply
RBS50Y - Any firmware in the pipeline since 2.3.5.32
steve8411
Apprentice
I have an RBS50Y attached to my RBR50 +2 sats wifi network set up in AP mode.
The RBS50Y seems to disconnect almost monthly like clockwork.
Cant say I could nail it down to router firmware or the RBS50 firmware but I tend to think the latter as I downgraded the router and the issue continues.
So I'm hopeful there may be a firmware fix ...
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: RBS50Y - Any firmware in the pipeline since 2.3.5.32
Hi steve8411,
We currently do not have a beta firmware for the RBS50Y. I'll reach out to our product teams to possibly get an ETA on the next firmware release.
Christian
Message 2 of 4
steve8411
Apprentice
Anything new on this?
The same model just received another update for use with Orbi Pro models..
Bug Fixes:
  • Fixes a DNS problem that intermittently causes loss of connectivity
  • Fixes the issue where MAC ACL entries can be lost
  • Fixes the issue where the third radio can stop working after Dynamic Frequency Selection (DFS) detects radar presence on a channel too many times
  • Fixes the issue where the Insight app or Insight Cloud portal show incorrect information in the device dashboard page when there are multiple attached devices
  • Fixes the issue where the password can be recovered only if the user name is 'admin'
  • Updates the HTTP Certificate
This seems like some applicable fixes that may solve my problem.
Can we get a version compatible with the standard ORBI rather than the Pro?
Message 3 of 4
Mstrbig
Master
Cant say I could nail it down to router firmware or the RBS50 firmware but I tend to think the latter as I downgraded the router and the issue continues.So I'm hopeful there may be a firmware fix ...
How far away is the RBS50Y from the closest sat or router? Have you tried resetting  and re-pairing the RBS50Y, since the RBR50 firmware downgrade?
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 461 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
