Orbi WiFi 7 RBE973
Reply
RBS50Y Keeps broadcasting NETGEAR-GUEST
computersteve
Apprentice
I HAVE NO CLUE HOW TO FIX THIS.. I have tried disabling guest / reenabling / repairing the satelites / uncheck broadcast SSID. The RBS50Y keeps broadcasting a NETGEAR-GUEST ssid that you cant actually even use cause you get no internet connectivity. I notice that it keeps this SSID even when I change the guestnetwork name. It broadcast this with the network that I named my Guest Network. Any fix ? is there a way to disable this through telnet ?
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 8
computersteve
Apprentice
Re: RBS50Y Keeps broadcasting NETGEAR-GUEST
Its broadcasting a 2.4GhZ NETGEAR GUEST & a 5ghz. So in my wifi scanner I see two of them.
Message 2 of 8
Guru
What Firmware version is currently loaded on the RBR, RBS and RBSY?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 8
computersteve
Apprentice
All the latest firmwares - V2.7.2.104 on my Orbi & Sats & V2.6.2.104 on my RBS50Y
Message 4 of 8
computersteve
Apprentice
I'm trying to downgrad the firmware to RBS50Y-V2.3.5.32. Apparently other people are having this issue & no one at Netgear is fixing it =(
Message 5 of 8
computersteve
Apprentice
It didn't work -- I tried telnet.. I will see if that works -
root@RBS50Y:/# config get wlg1_ssid
NETGEAR-Guest
root@RBS50Y:/# config get wla_ssid
Antonacci418
root@RBS50Y:/# config get wla1_ssid
NETGEAR-Guest
root@RBS50Y:/#
root@RBS50Y:/# config get wla2_ssid
Antonacci-Guest
root@RBS50Y:/#
root@RBS50Y:/# config set endis_wla1_ssid=0
root@RBS50Y:/#
root@RBS50Y:/# config set endis_wlg1_ssid=0
Message 6 of 8
computersteve
Apprentice
So it seems like Netgear is pushing this upgrade automatically. Meaning when I downgraded to 2.3.5.32 it automatically updated back to the buggy firmware. It seems the only way to fix this till Netgear fixes it is through Telnet using commands -
Message 7 of 8
Guru
Please make contact with NG support and let them know about this. NG will need to review this for your unit.
Good luck.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 796 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
