× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBS50Yv2
Matiasgalli
RBS50Yv2
Quisiera extender mi red mesh hacia el parque . Tengo actualmente un sistema orbis 752 . Es compatible algún sistema para exterior que sea compatible con esta serie orbis ? Ej RBS 50y
Message 1 of 4
Guru
Re: RBS50Yv2
there isn't currently an outdoor rated AX orbi. You can use the RBS50Y but you'd have to use it in extender mode and not orbi mode.
Message 2 of 4
Guru
Re: RBS50Yv2
In inglese per favore
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Message 3 of 4
CrimpOn
Guru
Re: RBS50Yv2
The Orbi RBS50Y has two modes:
Extender, which will connect to any WiFi router, including the 750 series, and
Satellite, which connects as a satellite only to the original Orbi ac models.
Netgear has not announced any outdoor rated models compatible with the AX products.
What many user do is place a compatible satellite inside a weatherproof enclosure, for example an RBS750
https://www.amazon.com/s?k=weatherproof+router+box&ref=nb_sb_noss_2
Google Translate:
El Orbi RBS50Y tiene dos modos:
Extensor, que se conectará a cualquier enrutador WiFi, incluida la serie 750, y
Satélite, que se conecta como satélite solo a los modelos Orbi ac originales.
Netgear no ha anunciado ningún modelo clasificado para exteriores compatible con los productos AX.
Lo que muchos usuarios hacen es colocar un satélite compatible dentro de una carcasa resistente a la intemperie, por ejemplo, un RBS750. https://www.amazon.com/s?k=weatherproof+router+box&ref=nb_sb_noss_2
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 754 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
