- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBW30 - Firmware 2.3.0.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to download version 2.3..0.4 firmware for the RBW30 but it does not download completely. I get a .chk file in the zip from each download location I can find, which means the zip is not complete. Does anyone have a complete download of this version?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a different browser? IE11 or FF or Opera?
You can try to rename the file extension to from .chk to .img and see if this works.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBW30 - Firmware 2.3.0.4
I just tested and it downloaded perfectly. Have you tried a different internet browser? or computer? Clear cookies/cache/etc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had no problem to download the zip file from the Support site.
I have it in my Dropbox here: https://www.dropbox.com/s/6y2pguadazyt146/RBW30-V2.3.0.4_1.0.5.zip?dl=0
- Mark as New
- Bookmark
- Subscribe
- Permalink
the .chk file is correct. If you were able to unpack the .zip file and you found the .chk file, this means the .zip file completed the download correctly. Use IE11 or FF web brower too apply the FW update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBW30 Firmware download is corrupt. The internal IMG update file is in a CHK format. I have downloaded the same file with two different browsers. Please update ZIP file
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your file is also corrupt. Needs to be an IMG file, not CHK.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried changing the file extension and it said it was the wrong firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working.
Ya, the file isn't corrupt, the file extension just needs to be changed. NG should be catching this to ensure the files are of the correct type for each model.
Enjoy.
@stevefxp wrote:
Seems that renaming it worked!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I thought it was strange that the file had a chk extenstion, but I was able to update the firmware without changing the extenstion. Worked fine w/o rename
- Mark as New
- Bookmark
- Subscribe
- Permalink
Indeed. Here too.
Netgear wobbles between chk and img – just read the literature – both of which can baffle users who do not follow the instructions and try to open the file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wondering if this a browser handling issue rather then a FW or device issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting this. Tried to update RBW30 via the app which says firmware is up to date, but shows V2.2.1.210 in the app and not V2.3.04 as well online on my iMac and won't update. Tried changing the file name to an img file, but didn't work on Mac OS MOJAVE 10.14.3
Hopefully, Netgear will change the format, as at lost as what to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try using FF or Opera browser on your iMac PC to send the file. The file doesn't need to be changed.
What is the current FW version loaded on the RBW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply and don't know what FF is, nor do I have Opera, but guess could try with that. Customers should not have to go thru loops in updating the firmware. Have the Netgear wireless router, etc for over a year and always difficult when updating or when they changed the app. If I had to do it again, would not buy anything from Netgear. Am just a casual home user.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear does not make upgrading firmware that easy. Posted in this feed that I was having trouble in updating in ios and mac os. Both the app on the iPhone and online in my Netgear account shows firmware" "up to date" but not showing the correct firmware both in the app and online.
This sucks period, tried to update via FF and the results are the same, " up to date", but still shows old firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, Tried it and the result is the same. See last post.
In plain English it sucks in trying to update, should not be that difficult. Maybe they need to learn something from Apple. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your picture shows that you are trying to do an automated update from the FTP server. It seems that Netgear has yet to put the newest firmware on that. This explains why you see "No new firmware version available".
If you look at the screen you posted, you will see that there is a "Manual Update" option. That is the way to go.
Retrieve the firmware file for your RBR40, unpack it to get whichever file it offers (chk or img). Put the file where you can find it.
Then click the Browse button above. Find your firmware. Click Upload.
By the way messing around with different browsers isn't likely to change anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much! Had no idea that was the problem, before did download a .chg file but could not open it on my iMac. Hopefully, it will be updated online as well as in the app. Funny, Netgear sends out an email that an update is available and then your unable to do it, least as far as am concerned.
Again, thank you so much and I'll try checking again in the app and online later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
chk files are there for you to open.
You download a zip file and extract the chk file. I gather that iMacs have an unzip feature built in.
You simply have to upload that in the way I explained above.
