× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Rb50 satellite keeps turning k after pulsing white, updating firmware, syncing, resetting dont work
StupidWifi
Message 1 of 4
StupidWifi
Re: Rb50 satellite keeps turning k after pulsing white, updating firmware, syncing, resetting dont w
To clarify, my satellite isn't very far from the router, about 20 feet, so it shouldn't be a range issue. However, any thing I do results in the satellite pulsing white for a couple of minutes, and then staying on pink indefinitely.
Message 2 of 4
Guru
What FW is on the RBS and RBR? Should be same version of FW on both.
Updated RBS first then RBS lastly?
Try a factory reset and the RBS and RBR and set up from scratch:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS8...
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Message 3 of 4
CrimpOn
Guru
The subject line mentions updating firmware.  Orbi routers appear to be sensitive to the sequence of firmware update.
(If the router and satellite are on different versions, they may not communicate.  Personally, I think this is insane, but that is certainly what appears to be the cast.  That is why the recommended practice is to update satellites first and update the router after all satellites have been updated.)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 336 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
