Browntownnj's avatar
Browntownnj
Rbk50 lastest firmware 2.7.2.104 transmit power skipping 75%
When I go to adjust my transmit power which used to be set to 75% on a previous version of the firmware I notice my options are now 100%, 50% and 25% only. Anyone else have this issue or know why I’m missing the option for 75%?
  • CrimpOn's avatar
    CrimpOn
    My experience as well, except that I blast away at 100%. Maybe 75% was so close to 100% that there was no point in having it?
    If I were the Engineering manager, I certainly would not authorize work time to change something like this, unless it was to put in all the possible values.
    • CrimpOn's avatar
      CrimpOn
      Release notes: "Fixes security issues"
      • vajim's avatar
        vajim
        Master
        Perhaps
        Normally release notes explain what changes the firmware update provides.  That is to include all changes, security, cosmetic, or otherwise
        The fact that we're dealing with netgear has often revealed a whole different animal
    • Browntownnj's avatar
      Browntownnj
      I didnt see it in any release notes...but I couldve missed it. however, either way when I had my system set to 75% I had no issues...no dropped wifi calls, no dead spots...everything was working great. Now I have to choose between 100% which causes a lot of over lap and dead spots or 50% which again leaves dead spots in different areas. UGH
      • vajim's avatar
        vajim
        Master
        Imho....I doubt turning up the power is the cause of your over lap (?) or vice versa, unless your neighbor is in your back pocket.  It's more than likely another fault of a vicious firmware update.  Just a guess.
