- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remote Desktop on a Mac
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can connect my laptop to my iMac at home via Remote Desktop. But when I'm at work it will not connect. It says can't connect check firewall etc... I don't have a firewall at home.
As far as firmware. I restarted and reset everything this morning before I came to work. So the firmware has been updated. Does anyone have any hints, tips?
Thanks,
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remote Desktop on a Mac
The easiest way for you would be to connect yourself using VPN from computer at work to Orbi then connect to the iMac exactly as you do when at home. Have you tried that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply! I have limited knowledge about VPNs, I know what they do but how would a VPN help?
Thanks
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
VPN is a secure tunnel between your computer and the internet. You can use VPN to eastablish a tunnel between your computer at work and Orbi.
By doing so you will be seen by Orbi as if you're sitting at home with a private IP address, so you will have access to the Orbi network exactly as if you have wifi connection to Orbi.
To configure VPN, you need first to configure DDNS in Orbi then configure VPN. You can find both settings under the >> ADVANCED >> Advanced >> in the web GUI.
I hope that helps.
