× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Replacement Adapter - Orbi Satellite
Jazijia
Hi all
I have an Orbi RBR20 system and the satellites are RBS20 model. One of the satellites power adapter has malfunctioned and is out of warranty, so I have to buy a replacement.
The model number of the adapter is 2ABB018F and I need to know the size of the plug to be able to buy the correct sized adapter. The size isn't written anywhere and I don't have the tools to measure it.
Can anyone help me with identifying the size as I am outside US and have to rely on Amazon.
Thank you
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 14
Guru
Re: Replacement Adapter - Orbi Satellite
Find one on Amazon that matched the putout voltage and amps as the original one.
Message 2 of 14
Jazijia
That's the easy part and I got that. I need to know the size of connector pin that goes in the satellite.
Message 3 of 14
Guru
Might look at the spec sheets to see. Most of the pin connectors are all the same and general size. Even if you do a search on replacement power adapters, the pin connector should be the same. Can ask the seller to confirm this as well.
Message 4 of 14
Jazijia
I couldn't locate the spec sheet and also called up Netgear but they had no idea.
Message 5 of 14
Guru
Message 6 of 14
Jazijia
Hey thanks for this. I think if this works for other Orbi systems it should work with mine.
Message 7 of 14
Guru
If not, Amazon has good return policies.
Good Luck. Smiley Wink
Message 8 of 14
Reinate
i wanted to place a satellite on top of the wall cabinets on my kitchen but didn't have an outlet nearby, so i picked up this power adapter, it's really nice.
Message 9 of 14
Guru
Which adapter did you pick up?
Message 10 of 14
Webheadjunky
Hi dont want to hijack this thread. I am in UK. I have purchased used RBK50 set and was looking forward to setting it up. Idiot that I am, I cut the wire on one of the adapters when removing bubble wrap! Could you recommend a replacement please? There is one on Amazon that appears to be unavailable. Grateful for your advice.
Message 11 of 14
Guru
Contact NG support.
https://www.netgear.com/support/#
Message 12 of 14
Webheadjunky
Thanks. I could not see an option to raise a ticket with support? Any tips?
Message 13 of 14
Guru
You have to create a user named account at that link. Then onces your in, you'll be able to file a support ticket.
@Blanca_O
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3525 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
